The same as?
  • jrdn223
    • Jun 2004
    • 138
    The same as?
    I've been havin some hesitation problems while running, so i did the mototronic thing and it brought up the code for the air mass sensor. Is that the same thing as the air mass(flow) meter?
  • Digitalwave
    is a poseur
    • 6300
    Yes it is. I have a working won laying around if you want to buy it to test.
    RISING EDGE
    • kencopperwheat
      King of Kegstands
      • 14396
      Hesitation can also be caused by the fuel pressure regulator (at least mine was). You might want to check that also...
      Originally posted by Gruelius
      • jrdn223
        • Jun 2004
        • 138
        Thanks but i actually have a spare one as well. I'll put in on a see if it solves the problem
