O2 Sensor
  • Rhino
    • 156
    O2 Sensor
    will a 87 325 o2 sensor fit a 1992 318ic?
    • 37832
    No.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Rhino
      • 156
      Why not?
      • Rhino
        • 156
        /bump, i wanna know why not.
        • Sean
          • 5793
          It uses an older style connector, I believe.
          - Sean Hayes
          • Rhino
            • 156
            The one i want to put in my car is a universal 87 325i o2 sensor so wiring shouldnt be a problem. Could there be any other issues.
            • Sean
              • 5793
              There's a couple connectors, if I remember correctly. On my old Eta, I think the 02 that was attached half way down the exhaust had a TWO prong connector. Then, up in the engine bay, there was the 4 pin connector used by later years. When I swapped to I-exhaust, the I-o2 connected right up.
              Either way, if you can change the connector to what you need, you shouldn't have trouble. As long as you get the heater, ground, etc etc all the same.
              - Sean Hayes
              • E30Gus
                • Jun 2008
                • 781
                There is a write up that says you can use a mustang 4.0 O2 sensor in an e30. the price difference is huge. Has anyone done this before? Is there a difference?
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  Bump. Just bought a 94 Mustang 5.0 O2 sensor for $58 new. Is there a wiring diagram anywhere os some instruction on which wires to splice?
                  Originally posted by Gruelius
                  • SpecM
                    • Oct 2005
                    • 4531
                    black to black, white to white, grey to grey
                    get creative with a ohmmeter
                    1989 cirrisblau-metallic 325i
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      ... there are two white wire.
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        bump.
                        There are two white wires. Is there any way to discern the difference between them?
                        • SpecM
                          • Oct 2005
                          • 4531
                          they are for the heater, and they are interchangeable
                          • DrewC
                            • Nov 2008
                            • 61
                            I'm currently trying to put in a new O2 sensor in my '86 ES. I followed the E30world writeup with the Mustang sensor but it won't thread in. When I bought the car the O2 sensor was dangling down and all beatup, so I'm not sure if the exhaust bung's threads are fine as I can't test factory fitment verses my new one.
                            Should my Mustang O2 just thread right in? If it should, it's not, so what are the thread dimensions so I can get a tap for it?
                            1986 325ES LeMons Racer
                            • lordofthewaters
                              • Oct 2005
                              • 714
                              Just get a thread chaser for an O2 sensor. M18x1.5
                              Sarcasm is a body's natural defense against stupid.
                              When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
                              "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
                              Old age and treachery will always overcome youth and skill.
