No power at all.....
  • SpartanTiger81
    • Sep 2007
    • 555
    So I woke up yesterday morning only to find my car is getting no power what so ever. No lights, no radio, NOTHING. I went and had the battery tested and its a good battery. What next??
  • Turf1600
    • 9815
    Bad ignition switch? Blown fuses? Bad relay(s)?
    • SpartanTiger81
      • Sep 2007
      • 555
      I have only 1 blown fuse but thats to number 28. 28 is the lighter and Radio?
      • Turf1600
        • 9815
        Time to break out the volt meter amigo.
        • SpartanTiger81
          • Sep 2007
          • 555
          Is it hard to change an ignition switch?
          • Vagcycle
            • Jul 2008
            • 76
            Could be the fuseable link that runs from the battery.
            • SpartanTiger81
              • Sep 2007
              • 555
              Idk man, I'll check it. But I just realized that it couldn't be the ignition switch because I can't even turn my park lights on.
              • Vagcycle
                • Jul 2008
                • 76
                Dude, after sayin that I deff think It's the fuseable link.
                • SpartanTiger81
                  • Sep 2007
                  • 555
                  is it under the plastic guard in the trunk?
                  • mattdk318i
                    • Jun 2006
                    • 3953
                    where are you located in SC?
                    • SpartanTiger81
                      • Sep 2007
                      • 555
                      Spartanburg
                      • mattdk318i
                        • Jun 2006
                        • 3953
                        ah,ok
                        • Vagcycle
                          • Jul 2008
                          • 76
                          There are two positive wires running from teh battery, one is a much smaller wire. You might have to pull the carpet up and whatnot.
                          The smaller wire has a fuseable wire in it. If it is toast than this would cause it not to have ANY power.
                          To figure this out also, an easier way. Open the hood, on the passenger side by the fire wall there is terminals for the postive. You should be able to see them. Get some kind of voltage meter and see if your getting power if not, check that wire.
                          • SpartanTiger81
                            • Sep 2007
                            • 555
                            Where can I find replacement fuseable link? I may have to go borrow a voltage meter.
                            • SpartanTiger81
                              • Sep 2007
                              • 555
