I think they sell it at autozone possibly. I'm not sure. Maybe home depot or something. It happened to me. Make sure you get a heavy gauge, with a strong fuse. A weak one will just blow again.
No power at all.....
No, but I cut the old one out and spliced the wires together just to test. I am still getting no freakin power.
Well I figured out what it was! It was the ground wire no making good contact to the ground! But, now I have to find a fuseable link. Called the dealer and they dont have them. Is it a 50a agc fuse?Last edited by SpartanTiger81; 07-09-2008, 03:08 PM.
how far do you have power to? And how many volts in your battery (and 11 is not over 90%)? Do you have power at the terminal at the front right firewall? If yes do you have it at your fuse/power distribution box? There are no fuseable links between the battery and the junction at the firewall. is your ground strap tight?? You should figure those out first.Comment
Well I have power now. I had to sand down the end of the ground wire a bit and wala I got power. I just need to know the amps of the fuseable link so I can replace it.
There is a fuseable link in between the battery and junction on the fire wall.how far do you have power to? And how many volts in your battery (and 11 is not over 90%)? Do you have power at the terminal at the front right firewall? If yes do you have it at your fuse/power distribution box? There are no fuseable links between the battery and the junction at the firewall. is your ground strap tight?? You should figure those out first.Comment
