Bought a 318, need advice!!!!!
  • bimmerboy12
    • Jun 2004
    • 1057
    hey guys, bought a 1985 318i, has a few issues. When I am driving very slow, like 4-5 mph, and swerve back and forth drastically, there is a horrible grinding noise from the rear, but in normal driving it does not happen. If any one can help me out, that would be great! It has a limited slip rearend.
    Brian
    1988 325iC Project - FINISHED!
    Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
  • kylebes1
    • May 2004
    • 2804
    advise: you should never buy an m10 car!! unless it is the powerful varient, the s14.
    I have an 84 318i and I drove with the 90 hp four cylinder for about 6 months and have now swapped to the m50.
    The LSD is pretty good on mine as well, got me messed up twice in the rain.
    • Rob
      • 8166
      wow, what an informative and topical post!
      BEERTECH
      • bimmerboy12
        • Jun 2004
        • 1057
        That did not help me at all. Thats great you swapped in the M50 but I am not doing that nor do I care.
        Any ideas on my problem, anyone?
        • brodee
          • Jan 2004
          • 2914
          Rear wheel bearing maybe. Do you feel a vibration at other speeds? Also climb under there and check all the suspension and bushings and make sure nothing is rubbing. When you swerve back and forth and throw the weight around it can cause things to rub if bushings are bad.
          "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
          1988 M3 - Track Rat
          1989 325iC M50 Vert
          1989 325i Coupe
          1991 318is
          1995 318ti Club Sport
          2006 330i e90
          2008 Tundra Crewmax
          • trent
            What is wrong with an M10? So you don't like 2002s either? What do you actually know about them? Why don't you eat a big bowl of dicks and shut the fuck up.
            Bimmerboy, check the driveshaft centerbearing and flex disk as well. Also, check the differential, subframe, and trailling arm bushings.
            • hamann318is
              • 3382
              What's wrong with the M42? That's a 4-cyl varient...
              The BMW 318 is back. With a vengeance.
              • Charlie
                kid tested, administrator approved
                • 6686
                I second this, as well as Trent's "big bowl of dicks"motion.
                -Charlie
                Swing wild, brake later, don't apologize.
                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                FYYFF
                • Kondour
                  • 243
                  change the differential fluid... Use either blended or synthetic and noise will go away
                  • e9nine
                    • 1890
                    hopefully....
                    • bimmerboy12
                      • Jun 2004
                      • 1057
                      car
                      If i change the fluid, do I need to add that limited slip additive? I know I had to put it in my camaro when i had it and it sounded like hell until I did. dont know if this is the case with bimmers
                      • e9nine
                        • 1890
                        No need to get the additive. Just get the correct specified oil. Its listed in the Bentley...I forget the specs on the oil but someone else will chime in on the exact one needed or I will post it later when I get home
                        • e9nine
                          • 1890
                          the m42 is in a class of its own. Loved by few, misunderstood & unappreciated by most.
                          • hamann318is
                            • 3382
                            The best kept BMW secret. At least some of us get it. :D
                            • James Crivellone
                              Head Janitor
                              • 6305
                              I think the ETA Falls under that catagory as well :D
