e30 top speeds
  • kylebes1
    • May 2004
    • 2804
    e30 top speeds
    I was reading through the tech section and the e30 spec chart shows the Alipna does like 150, is that what it is geared for or will it go that fast?
  • Jon325i
    • 6934
    Alpina E30s were not your typical car. They usually massaged the engine, suspension, etc. to get their desired result. To get an E30 to hit 150 would take a substantial motor upgrade since these cars have the aerodynamic efficiency of a brick. Plus I would question the accuracy of the cars' speedo or if it was running a slightly under-sized wheel/tire combo. Either of these can effect what the needle does.
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
    • kylebes1
      • May 2004
      • 2804
      Yeah I figured about the brick and the speedos do read little faster.
      • e9nine
        • 1890
        If you want to go super fast.....get a 2.93 diff.
        I would highly advise against this as the speeds you will get up to (if you can) will require you to get a cage and massive protection in case of the worst happening.
        I would rather say you just get something to give you decent mileage and still allow you to scoot.
        Diff ratios are of course matched with your tranny and motor setup..the 2.93 was a typical stereotypical piece of advice :!:
        • Beej '86 325es
          • 2639
          Don't the E36 M3's use the 2.93? Those things top out at like 170 don't they?...granted they use a completely different gearbox.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • Skafrog
            • 1730
            no way in hell will an e30 get up to a 2.93's full potential. You WILL slam into an aerodynamic wall around 140, and even sooner with a 2.93. If you want to go faster, go to a 4.10, since 140 will be hitting the low end of the rev range in 5th with a 2.93
            NASA MidSouth TT Director / GTS2 #018
            Mods: Coastal PS Fluid, 10w40 Oil
            Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
            • ian332isport
              • 124
              I was lucky enough to test my top speed recently. It was part of a photoshoot for Performance BMW magazine.
              Before any safety loving tree huggers get on my case, it was done on an old airforce runway that was two miles long, and seriously wide. No members of the public were put at risk during this test.
              Anyway, back to top speed :D , I managed 157mph before I had to hit the brakes. With a bit more runway, I may have got 160, but that would be about it.
              This was measured using one of these, so is an actual speed measurement, not a speedo reading.
              Cheers,
              Ian.
              • Rob
                • 8166
                Ian is that indicated or on GPS?
                Alexmc hit 157 on the GPS, I dont know how accurate the speedo was.
                BEERTECH
                • ian332isport
                  • 124
                  That was GPS.
                  For the record, my speedo was reading almost exactly the same speed.
                  Cheers,
                  Ian.
                  • kylebes1
                    • May 2004
                    • 2804
                    Ian yu are my idol! I know with enough power I could do 160.
                    What diff do you have? And I you said you have a 6 speed right ? probably geared at 0.87 or so, right?
                    I only have a 5 speed with a 1:1 fifth gear.
                    • ian332isport
                      • 124
                      Hi Kyle,
                      My diff is a 3.64 LSD, and yes it is the 6 speed box. I believe it's 0.83:1 in 6th.
                      Cheers,
                      Ian.
                      • denisbmwm5
                        • 347
                        Couple days ago i toped out my 87 325is at 147, there was no more room left on the rpms. Guess i need a lower gear diff. Also thats with a turner chip, with the stock one i think i toped out at 120-125. Hope that helps.
                        • Jand3rson
                          • 37587
                          What gearbox are you using for the 6-speed? Is that with an M20?
                          • ian332isport
                            • 124
                            It's the gearbox from a Euro e36 3.2 M3. This is connected to the Euro S50B32 engine, not an M20.
                            Cheers,
                            Ian.
                            • Jand3rson
                              • 37587
                              It's the gearbox from a Euro 36 3.2 M3. This is connected to the Euro S50B32 engine, not an M20.
                              Cheers,
                              Ian.
                              Very good. Thanks for clearing that up. :D
