Help me out - sputters and dies
  • Lurker27
    • 821
    My e30 has been a little finicky in the past with cold starts, but never ANYTHING like this. The timing belt almost went (sheared some teeth) 2 years ago, but the engine was pronounced OK then, just thought I'd give background. Once or twice I have noticed hesistation in the acceleration, and performance and gas mileage (calculated 16.7 mpg in an autotragic)
    My symptoms have started recently and have gotten worse quickly. First, the car is difficult to start. It turns over, but in the initial surge of revs, it may or may not "catch" and idle at a normal rate. If it gets to 1000 or so I can nurse it along with gas. I drove home toggling back and forth in neutral and with brake and gas to modulate my speed while feeding the car the whole time.
    Any time I am driving and I have my foot off the gas, it may stall out (loses all responsiveness and rpms slowly drop to zero, rather than all at once). Once it stalls out, it seems MUCH harder for it to start. If I attempt to start the car and it does not reach idle, quick subsequent attempts are much less likely to succeed (I have to wait 2-3 minutes before a restart is likely to succeed).
    My tank is getting low again, and I'm wondering if maybe I have water in my tank from bad gas at some point (How do you go about purging this?). I also feel like it could be something idle related - ICV sticking perhaps? My fuel pump was replaced recently, but I do not know when the plugs or injectors were (prior to ownership).
    Any insight ot this water or diagnostics I can run (planning on disconnecting the ICV and tapping it with a screwdriver to see if it sticks), would be greatly appreciated.
    '89 335is +turbo
  • Danny
    • 14216
    Seafoam
    • atomic
      • Jun 2007
      • 5691
      Could be a fuel related issue
      or
      Source a good MAF / AFM and swap out. I have seen them cause some similar problems if they are going bad.
      • Lurker27
        • 821
        Originally posted by Danny
        Seafoam
        As a bad/watered gas solvent?
        '89 335is +turbo
        • E30_fiend
          • Apr 2006
          • 7348
          +1 on the AFM comment. My buddies mom's cabby was doing the same things. We tried putting a full tank of 91 octane in with two bottles of octane booster and still nothing. Then we took the AFM off and replaced it with a known working one and problem solved.
          Check into that and try it out if possible.
          Taylor
          • Lurker27
            • 821
            Thanks for the suggestions, guys!
            '89 335is +turbo
            • DCColegrove
              • 2748
              Check for air (vacuum leaks) if you can check the fuel pressure.
              If the DME relay is more than 50K old just replace it.
              Kind of hard to diagnose just from the description you have...
              if you get this far in checking fuel press air leaks let me know...
              • mattdk318i
                • Jun 2006
                • 3953
                check your FPR for good measure. Take off the vacuum line and make sure fuel isnt bypassing the diaphram and getting into the vacuum lines. That would be a definite sign that it needs to be replaced
                • Aptyp
                  • 6584
                  When my fiends AFM went, his car smoked like crazy.
                  I would check for vacuum leaks as well, especially that hose from valve cover to throttle. been my issue before. Intake boot? Seafoam is an awesome idea as well. Checked your plugs yet? Report back soon.
                    • 34844
                    bad mileage, hard starts - I would check the coolant temp sensor before anything else.
                    do you have a bentley? there are basic tests you can do with just about every system on the E30. all you need is a decent multimeter. It eliminates a lot of guessing and threads like this one. good luck on your problem.
                    • Lurker27
                      • 821
                      Unfortunately my multimeter is dead - I pulled out my bentley and I suspect the carbon canister but need to perform the electrical checks too. I'll keep this updated so it can be archived for anyone that has the problem in the future.
                      '89 335is +turbo
                      • Lurker27
                        • 821
                        Update - Disconnecting the ICV yielded no change in idle, so I think that's the problem.
                        I'll probably seafoam, fuel injector cleaner, and check out the O2 sensor while I'm in the mood. I need to pull the injectors, I suspect it's been running a bit rich also.
                        '89 335is +turbo
                        • E30_fiend
                          • Apr 2006
                          • 7348
                          Make sure you get some new o rings for the injectors. The las thing you want is one of your injectors to pop off while driving. Also, if you're running rich, I doubt its your injectors. Its possiblet but doubtful. If you're running rich its either your O2 sensor or the AFM.
                          When I was having a problem with running rich, I changed out my O2 sensor and it solved the problem immediately once it warmed up.
                          Taylor
                          • Lurker27
                            • 821
                            That's logical, Taylor; Thanks!
                            '89 335is +turbo
