ECU replacement.
  • ayemattyyy
    • Apr 2008
    • 411
    ECU replacement.
    how hard is it to replace an ECU(engine control unit) on an e30? Looking at an otherwise clean car and would like to know how hard it might be to replace. Thanks!
  • smonkbmw
    Professor
    • Jun 2006
    • 4549
    how do you know it needs to be replaced? symptoms?
    its not hard. 3 screws above the glovebox, 2 bolts in the ecu. its all right there.
    • ayemattyyy
      • Apr 2008
      • 411
      the seller said the car's on it's fourth ecu but say's it's something different. how could I ask him to test it to find out what's wrong? The engine cranks, but get's no ignition.
        • 34847
        is it getting spark? if there is no spark at all, either the coil/wiring is fubar'd, or the crank sensor isn't working. if the car is getting spark then the ECU and crank sensor are probably fine. I'd be amazed if a car went through 4 ECUs though - something else must be wrong.
        • E30 Cabrio
          • Oct 2006
          • 1954
          On a scale of 1 - 10 with 1 being the easiest and 10 the toughest, it's about a 1.5
          I agree though - ECU's rarely fail and whatever is causing the ECU to fail so frequently could be a symptom of a bigger, hidden problem.
          He could also be BS'ng you about the ECU being the cause of the car not starting and it could have other problems that aren't as easy to fix as an ECU
          Buyer beware.
          See if you can find a cheap ECU on ebay or locally and swap it out and see if the car starts and runs, but I would be hesitant to buy and drive a car that goes thru ECU's so quickly.
          Good luck.
          1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
          Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
          Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
