what would cut power to my ecu?
  • JAM
    • Feb 2007
    • 524
    ive had a problem for a while now... the car will be driving fine, then all of a sudden it will buck, sputter, cut out, ect. i was watching the ms box when it was happening yesterday and the ms will completely turn off, then turn back on and the 2nd light (lit up fully during warm up) will quickly flash. im thinking something is being grounded out intermittently.
    any common wiring locations to look at? where is the power supply for the ecu ran to?
    thanks
    jam
    Originally posted by Mr Watsonsilver
    driving boards?
    The power for the ECU runs through the main relay. In this case that would be the first thing to check/replace.
    • JAM
      • Feb 2007
      • 524
      ugh this is so frustrating. the wiring on this car is such a mess. whoever did the swap half ass'd the shit out of the main relay wiring, that is my problem
      i replaced the actual relay itself, but no go, still has the same symptoms
      any other ideas?
      driving boards?
      • backtrail69
        • Jul 2005
        • 4471
        Are you sure its not a ECU reset? I had problems with the wiring for my VR sensor when i first put on my coil packs and it did a similar deal. I Relocated the wire and the interference went away.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
