Hvac panel problem..
  • SpartanTiger81
    • Sep 2007
    • 555
    My Hvac panel won't stay flush against the rest of the dash. I can't find out what's holding it in. Is it a clip?
  • Jean
    • 18228
    2 screws on top behind blank covers/switches, and two on the bottom, above the ash tray, you can feel them with your fingers.
    • SpartanTiger81
      • Sep 2007
      • 555
      I'll go check it out real fast..
      • SpartanTiger81
        • Sep 2007
        • 555
        I can't find them? Took my radio out and popped the switches out and everything..
        • jrobie79
          • Mar 2006
          • 2525
          when i removed my panel to change the bulbs, i noticed it would not go back in, so if you check those screws, they are up there, just use a small flashlight and see if you can look underneath. however if you check those screws and get those in there pretty good, my aftermarket stereo cages was holding it out just a bit. it seems one of the mounting tabs on the cage bent down to stop the panel from going back all the way in.
          1991 318i ---- 308K - retired
          • SpartanTiger81
            • Sep 2007
            • 555
            I fixed it.
