Antifreeze out flywheel cover?
  • NewmanJ87
    • Jun 2004
    • 50
    What could be causing this, I just got the car back together after an oil pan and head gasket and now I ran into this problem!!
    Jordan, when he has nothing bad to say, he says nothing at all. Cuz he's way better than us, right?
  • jflower
    • 262
    are you sure it's not just dripping down the bellhousing? could be a leak in the headgasket at the back of the motor, and it's just dripping all the way down. could also be coming from the rear coolant pipe on the head. sometimes it's a bitch to get that one back on.. could be anything if you just did the headgasket...
    more investigating is needed.
    king of bad decisions.
    • James Crivellone
      Head Janitor
      • 6305
      check the hoses going into the heatercore ( at the firewall)
      • Jordan
        • 12916
        The pipe that comes out of the back of the head is the most common cause of this issue.
        https://mtechniqueabs.com/
        • ChocolateKrackers
          • Mar 2004
          • 233
          Jordan's got it. The coolant can't be coming out of the bellhouse unless (maybe) your so unlucky that a freeze plug jumped out and then it wouldn't be leaking, it would be flowing.
          "My backpack's got jets..."
          ~MC Chris is my co-pilot~
          • reelizmpro
            • 9552
            Hmmmm since you have an early car, I believe there is a freeze plug on the block that is covered by the transmission bell housing. This was slightly leaking on my old 85 325e. Just another thing to consider.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
