Flowrate of stock water pump. ?
  • LowR3V'in
    • 4209
    Does anyone know the GPH?
    I think the bentley has it in Liters. If anyone can help me out. :?:
    Thanks. :)
  • UNHCLL
    • 8790
    Below the radar...
    • M-technik-3
      • 18946
      Or here is a good pocket referance book Aviation Mechanic Handbook isbn 1-56027-132-9 Aviation supply and acdemics, inc asa-m-hb-1
      • LowR3V'in
        • 4209
        I don't understand your answeres...
        I'm asking what the flowrate is. :?
        • hamann318is
          • 3382
          Convert it your self, that's what they're saying...
          The BMW 318 is back. With a vengeance.
            • 34839
            google also has a conversion tool:
            • M-technik-3
              • 18946
              You have a bentley right? use the gph and convert it using Chris's link. My post was for a pocket size handbook with tons of useful aviation an automotive info. But it's a Avaition book thou.
              • LowR3V'in
                • 4209
                haha! I just want to know the flowrate.
                No, I don't have a bentley.. i want to know how many liter per hour
                it flows. Or gallon per hour.. doesn't matter..
                I just need the flowrate..
                For example: 34Lph :?:
                • RedBaron86325
                  • 386
                  I don't know if there will be a set flow rate since the rpm is constantly changing.
                  Don't forget the good things Hitler did.
                  • M-technik-3
                    • 18946
                    What do you need this for anyway? Are you converting to an electric water pump? Or are you doing an after run pump for a turbo unit to prevent coking and cooling issues?
                    • trent
                      There is probably a max flow rate before cavitation, but you are correct.
                      • LowR3V'in
                        • 4209
                        OMG
                        I'm looking for the amount of liters the pump can flow not how much liter/gallens
                        it flows at idle..
                        Yeah, I'm switching to electric and just couriouse to compare numbers.
                        Not for a turbo, but just to upgrade.
                        Thanks for helping guys..
                        Anyone with a bentley?
