What clutch and flywheel do you use for the M50/S50 swap when using a 260 trans?
Question for M50/S50 Swappers
-=PJ
CarDomain
2006 SCR-SCCA Street Mod Champion and WRX STi Killer :D
1991 Suzuki Bandit 400
1993 BMW 325is: M3 Cams, Bilstein/Eibach => High-Revving 4.8L
2000 Dodge Dakota: V8 + 5spd = Smokey Fun
2004 Pontiac GTO - RIP :(
"If not under warranty, live with it, or bend over and grab ankles."Tags: None -
trent
Re: Question for M50/S50 Swappers
Stock.Originally posted by PJ325iWhat clutch and flywheel do you use for the M50/S50 swap when using a 260 trans?
You can use E30 M3 if you really want. :) -
The twin cam engines use dual-mass flywheels that weigh something like 30+ pounds. You could exchange it for a stock M20 flywheel...that alone will remove around 10 lbs. If you're so inclined, you could take an M20 flywheel to a machine shop and have it lightened up some (like Metric Mechanic does) to around 13 lbs.....it shouldn't cost much either. That should offer a significant improvement in throttle response.
HTH
JonRides...
1991 325i - sold :(
2004 2WD Frontier King Cab
RIP #17 Jules BianchiComment
