Help! Can't get rid of clunking noise in the rear.
  • davidmc
    • 13
    I'm posting this problem again since I didn't quite get any satisfactory answers earlier. Here goes - I'm hearing intermittent clunking sounds in the rear section of my 89 325i -especially over bumps and road imperfections. I've replaced my H&R lowering springs thinking that was the culprit and installed new stock springs. However, the noise remains. What could be causing it? I've already replaced the bushings in the right-side area where the noise seems to be coming from and also tightened the battery housing and other trunk components. Guide supports are new as well. Any ideas, guys? FYI, I'm using the black type OE Bilstein shocks. It's really depressing me.
  • DanGillan
    • Mar 2004
    • 4061
    make sure your Rear Shock Mounts are tight, go pull off the lining in your trunk, 2 13mm nuts on each side...
    Dan
    • kencopperwheat
      King of Kegstands
      • 14396
      You're sure it's coming from the rear?
      Originally posted by Gruelius
      • iXer
        • 242
        Check everything to do with the anti sway bar in the rear (links and bushings).
        /Mattias
        • Jordan
          • 12916
          Zip tie down anything that moves :twisted:
          https://mtechniqueabs.com/
          • Dave
            E30 RAT
            • 11675
            Duct tape would be more effective, don't you think?
            Seriously - check the shock mounts. If those are good, start looking at every bolt, bushing and connection back there. Is your exhaust secured properly? What about something loose in your trunk such as your jack?
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
            • davidmc
              • 13
              Thanks for your suggestions. I've already done most of what you've told me to do in the past - tighten bolts, replace bushings, etc. But I'll check again and let you know.
              • Snowmann
                • Jan 2004
                • 459
                check your exhaust donuts, or just go in the back and shake the exaust, when the donuts are shot it allows it to swing so much it hits the sheet metal
                • Charlie
                  kid tested, administrator approved
                  • 6686
                  Check to make sure your spare tire is totally torqued down and not moving around.
                  -Charlie
                  Swing wild, brake later, don't apologize.
                  '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                  FYYFF
