Check Engine light on, what cause?
  • Rosica
    • Jan 2004
    • 240
    My check engine light to come on at idle, what causes the computer to output this? Since e30's have relatively archaic injection systems I would assume out of whack O2 senor readings would be the only thing to cause it, but I want to be sure.
    07 335xi Sport
    00 S2k
    01 A4 1.8t-Sold
    88 M3-Sold
    91 325iC-Totaled
    89 325iS - Sold
    87 325-Totaled
  • e30Matt
    • 5077
    Turn the key to the on position, and quickly but rhythmically fully depress and fully release the gas pedal 5 times. On your car you'll have to do this rather quickly, but you'll get the hang of it.
    The CEL will flash once, and then start flashing a four digit sequence. There will be fast flashes followed by long breaks. Write this number down and post it here.
    EDIT: These are the meanings of the codes. The code is listed to the right of the problem part. A code of 1444 means there are no problems.
    DME Control Unit 1211
    Air Mass/Volume Sensor 1215
    Throttle Potentiometer 1216
    Output Stage, Group 1 1218
    Output Stage, Group 2 1219
    EGO(O2) Sensor 1 1221
    EGO(O2) Sensor 2 1212
    Lambda Control 1 1222
    Lambda Control 2 1213
    Coolant Temp. Sensor 1223
    Intake Air Temp. Sensor 1224
    Knock Sensor 1 1225
    Knock Sensor 2 1226
    Knock Sensor 3 1227
    Knock Sensor 4 1228
    Battery Voltage/DME Main Relay 1231
    Throttle Idle Switch 1232
    Throttle WOT Switch 1233
    Speedometer A Signal 1234
    A/C Compressor cut off 1237
    A/C Compressor 1242
    Crankshaft Pulse Sensor 1243
    Camshaft Sensor 1244
    Intervention AEGS 1245
    Ignition Secondary Monitor 1247
    Fuel Injector 1 (or group 1) 1251
    Fuel Injector 2 (or group 2) 1252
    Fuel Injector 3 1253
    Fuel Injector 4 1254
    Fuel Injector 5 1255
    Fuel Injector 6 1256
    Fuel Injector 7 1257
    Fuel Injector 8 1258
    Fuel Pump Relay Control 1261
    Idle Speed Actuator 1262
    Purge Valve 1263
    EGO Heater 1264
    Fault Lamp (check engine) 1265
    VANOS 1266
    Air Pump Relay Control 1267
    Ignition Coil 1 1271
    Ignition Coil 2 1272
    Ignition Coil 3 1273
    Ignition Coil 4 1274
    Ignition Coil 5 1275
    Ignition Coil 6 1276
    Ignition Coil 7 1277
    Ignition Coil 8 1278
    Control Unit Memory Supply 1281
    Fault Code Memory 1282
    Fuel Injector Output Stage 1283
    Knock Control test Pulse 1286
    • Court M3
      • Jan 2004
      • 6713
      Does this only applies to cars with Motronic or all of them?
      Continuous For Sale Thread
      323i s50
      • e30Matt
        • 5077
        Motronic only, 84+.
        • James Crivellone
          Head Janitor
          • 6305
          Motronic only, 84+.
          its actually 87 and up (87 325is/i only)
          Motronia/Moronic 1.0 didn't have a CEL
          • e30Matt
            • 5077
            Motronic only, 84+.
            Err, yeah. That.
            • Kavkazia
              • 394
              I had same problem, and it was 02 Sensor, is it running little bit rich?
              If so, most likely your 02 sensor is out.
              95' M3.
              90' 325i Turboed.
              87' 325eS Fixed.
              • BMWE30
                • 12
                My 87 325 has a CEL, as does my friends 87e. It only has 4 codes though.
                • Rosica
                  • Jan 2004
                  • 240
                  OK, I got
                  Is that ICV, ICM, ?????
                  07 335xi Sport
                  00 S2k
                  01 A4 1.8t-Sold
                  88 M3-Sold
                  91 325iC-Totaled
                  89 325iS - Sold
                  87 325-Totaled
                  • Digitalwave
                    is a poseur
                    • 6299
                    Lambda is the oxygen sensor.
                    RISING EDGE
                    • Rosica
                      • Jan 2004
                      • 240
                      Are you sure the “Lambda Control 1” error code is the O2 sensor, the light only comes on at idle, and the O2 senor is a senor, not a control.
                      07 335xi Sport
                      00 S2k
                      01 A4 1.8t-Sold
                      88 M3-Sold
                      91 325iC-Totaled
                      89 325iS - Sold
                      87 325-Totaled
                      • skat 325is
                        • 296
                        Mines giving me this one
                        EGO Heater 1264
                        Someone care to explain ??
                        • e30Matt
                          • 5077
                          It's the O2 sensor... Lambda control is just an "official" name for it.
                          • Rosica
                            • Jan 2004
                            • 240
                            I cleaned the IV put in air filter, new plugs, and O2 sensor and nothing changed.
                            Now the car stalls on cold starts, if I tap the gas it revs to 2500 rpm. When its warm the idle is very rough and can be erratic. The check engine light comes on at idle and sometimes while driving.
                            I am going to try cap/rotor/wires and maybe collant temp sensor since its cheap. When I adjust the valves I will take a look at the new plugs I put in to see if they can tell me anything. After that I will break down and get a new ICV, but if that doesnt work i dont know what is wrong, any suggestions?
                            07 335xi Sport
                            00 S2k
                            01 A4 1.8t-Sold
                            88 M3-Sold
                            91 325iC-Totaled
                            89 325iS - Sold
                            87 325-Totaled
                            • Bill 84 318i
                              • 1600
                              Vacuum leak?
