I did searching, I just want to clarify and find out what you guys do.
SO, if I lift the motor up as high as it goes, basically so the heads against the firewall, I'll be able to get the oil pan out past the oil pump?! (http://www.strictlyeta.net/technical/oilpan.html)
Cause, that's badass if it's true! I thought for sure I'd have to drop the subframe a little to get the pan out all the way. Reason being, in this article (http://www.slidewaysonline.com/?q=node/41) has them jacking up the motor AND dropping the oil pump.
Anyway, let me know what you guys did.
