Speedometer not working
  • SpartanTiger81
    • Sep 2007
    • 555
    So I took out my Speedo to clean the gauge faces because dirt was caked up big time on them. Well, I popped it back in, and now my Speedo is the only thing thing not working. I'm thinking I don't have the single wire plugged in the right spot into the green connector. Can ayone tell me what notch the single wire goes into on the green connector?
  • ZM Blue Devil
    • Dec 2006
    • 13836
    usually it goes on the top spot...
    Levent
    %20levent@gutenparts.com
    Ladies:
    • SpartanTiger81
      • Sep 2007
      • 555
      Took my cluster apart again, and realized the speedo need would go up, but not down. So I pull the needle up a bit, and It worked! Now the need is like majorly off, and won't stay at the 0 mark. It goes down past the 0 mark. HELP!
      • TDE30
        • 7042
        Broken solder?
        - Trey
        E90 325i/6 (ZSP, ZPP, ZCW)
        E36 325i sedan
        E30 325i sedan
        Volvo 945T
        • SpartanTiger81
          • Sep 2007
          • 555
          Seriously? I thought I just could adjust the needles. I'm about 7 mph off.
          • george graves
            • 19994
            Yes, you can manually pull the needle, and re-situate it.
            Bit of advice? A metal eating fork makes a great device for pulling the needle, just use a paper towel to protect the gauge face.
            Originally posted by Matt-B
            • SpartanTiger81
              • Sep 2007
              • 555
              So I just pull the needle and reseat it? That's it? Thanks George!
              • george graves
                • 19994
                I can't tell you why your gauge is off. I can only tell you that, yes, you can pull the needle off and replace it in a new position. They are not indexed in any way. It's a round shaft - about as small as a sewing pin - and about 1/3 as strong.
                Oh - well I'm at it. another piece of advice - the actually needle pointer is stamped metal. It bends very easily, and since its a U-shaped channel, doesn't want to go back - so be very careful. But, you'll be surprised at how much force you have to apply to get it off.
                • SpartanTiger81
                  • Sep 2007
                  • 555
                  Fixed thanks to George!
                  • george graves
                    • 19994
                    Used the fork trick? Nice hun?
                    • SpartanTiger81
                      • Sep 2007
                      • 555
                      Yep the ole fork trick, haha! Thanks!
