Solid lifters
  • e30Matt
    • 5077
    Solid lifters
    Thought crossed my mind after reading about "high rev kits" for BMW engines...
    Are there any BMW engines out there w/solid lifters that would fit the M42?
  • BS87
    • 1606
    I thought i head something about the S50 Lifters fitting the M42... not sure at all though, i'm semi-drunk and it took me a while to even think of that.. :?
    • MattM20
      • 641
      if you mean fitting an entire engine, then the euro s50's had solid lifters
      • Streetspec_iS
        • 1622
        apparently the s50 lifters do fit the m42. the m42 is rumoured to be very closely related to the s50.
        sigpicM42 Brigade ... Throwing craze in the 318
        • e30Matt
          • 5077
          I remember hearing somewhere you can use the pistons as well?
          Could parts from an S14 or S50 be combined to finish out the job?
          • Streetspec_iS
            • 1622
            you can use the pistons, but the block needs to be bored a bit. they arent just drop in. this process apparentyl would bring capacity up towards 2.0l.
            nothing from the s14 is compatable without modification.
            • Streetspec_iS
              • 1622
              couldnt say to be honest. i mean, its obviously going to give you something, but whether or not it is economically viable,i dont know.
              i kinda like the idea of having a little 2/3 s50 thing going on. mmmm, 190hp. :twisted:
              • e9nine
                • 1890
                ..all you m42 guys are VERY :loco:
                • Rob
                  • 8166
                  dont forget the harmonic balancer, which is another limiting factor in the m42's revs
                  BEERTECH
                  • e30Matt
                    • 5077
                    Well, what could be done about it?
                    • Jordan
                      • 12913
                      Originally posted by robbieosterman
                      ... why don't we post everything necesary to get the M42 above 8,000 RPM's. I'm really interested.
                      Just swap a s14 in...
                      https://mtechniqueabs.com/
                      • e30Matt
                        • 5077
                        Or, we could figure out how to get the M42 above 8000RPMs.
                        • e30Matt
                          • 5077
                          Back on topic, I noticed awhile back that BMPD sold hi-rev kits for the 93+ M42 engines.
                          Just thought I'd share. Look at the durations on the cams. :shock:
                          • Streetspec_iS
                            • 1622
                            ha, rich!
                            • Rob
                              • 8166
                              look at those prices :shock:
                              there is definately a point of diminishing returns that is reached when you start spending $2200 on cams for a motor thats worth like $500
                              BEERTECH
