Clean/Rebuild/Coolant delete 325i Throttle Body
  • rwh11385
    lance_entities
    • 18403
    During the colder season, I experienced my throttle sticking a little bit on startup and driving, which I was told was NOT normal and it should be rebuilt/cleaned throughly.
    So I bought a used one from Ely, thanks. And can spend my spare time rebuilding this one. Basically, Jordan told me to take it apart and clean it well. I was wondering if there were any gaskets or such that needed to be replaced.
    I was also interested in what it would take to delete the coolant passage through the TB. I was thinking just seal off the connection on the TB and then use a male-to-male connector with the coolant hoses.....possibly cutting them as to shorten the circuit.
    I am not sure. thanks for the help.
    Oh yeah, anyone feel using the Dremel to polish / port the TB a little would help at all, or just a waste of time? I might if I am bored one afternoon.
  • Rob
    • 8166
    Re: Clean/Rebuild/Coolant delete 325i Throttle Body
    If you're having this....
    you shouldn't do this
    BEERTECH
    • rwh11385
      lance_entities
      • 18403
      yah, yah. I can see how you would say that, but I believe the sticky throttle is more of grime and crud, not as much temperature. it just seemed to have more often when it was winter.
      • UNHCLL
        • 8790
        wrong
        Rob is right
        porting TB is a waste of time.
        Below the radar...
        • rwh11385
          lance_entities
          • 18403
          Alright, so don't delete the coolant passanges, then? 10-4.
          Any gaskets, seals, or anything I should replace?
          • UNHCLL
            • 8790
            yes a cork one that seals the coolant thingy.
            take off the 3 hex? screws and you'll see the gasket. then just a new gasket to go between TB and intake
            Below the radar...
            • rwh11385
              lance_entities
              • 18403
              ah, thanks.
              WD40 + elbow grease + time should get it operating better than my current one.
              • UNHCLL
                • 8790
                ah, thanks.
                dont use WD40
                that isnt a lubricant.
                go buy some HHS2000
                Below the radar...
                • rwh11385
                  lance_entities
                  • 18403
                  ah, thanks.
                  dont use WD40
                  go buy some HHS2000
                  i was talking about cleaning it. usually works decent. or what else can cut crud?
                  • Rob
                    • 8166
                    purple power or simple green or equivalent, or hell, carb cleaner would probably work as well
                    BEERTECH
                    • Spaz
                      Crazy Canuck
                      • 2276
                      Originally posted by Rob
                      carb cleaner
                      is the best, hands down.
                      Cam .W '91 325is
                      Spaz's 1991 Alpine White???? S52 Build Thread...
                      • Jordan
                        • 12916
                        Don't use "purple power" or any other purple colored general purpose cleaners. They are acidic, and are particularly nasty to aluminum. It will eat/corode it.
                        https://mtechniqueabs.com/
                        • David325is
                          • 194
                          I just replaced this gasket in my car. I noticed something was wrong when a nice puddle of coolant appeared in the garage. The old gasket, when I got the thing apart, was in shreds. I put a new one in and the problem is fixed.
                          • M-technik-3
                            • 18946
                            Bucket of carb cleaner.
