M50 swap wiring question
    Call me an idiot, but I've never done a project like this before. I have a 92' non-vanos m50 sitting in my garage with a complete engine harness and ecu. Following the wiring charts on akgmotorsport.com, I spliced the m50 harness to an extra e30 connector I have. I'm still left with a bunch of wires on both sides of the connection. I know that the tach signal must be spliced in separately but what else am I missing?
    I noticed that most of the wires I spliced together are the same color on both the m50 and m20 harness, do I just continue connecting same-colored wires?
    Do I need the relay box from the M50 or can I use the one from the e30?
    If my questions aren't clear enough, I can take some pictures.
    Thanks.
    '91 318is
    hit me up with a pm when you figure everything out. Pics of this would be a nice addition to the e30 forum. I'm attacking this project very soon.
    Thanks
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
      i only used the wires on akg's website and had quite a few left over too. the car ran fine and all the gauges worked. you only need the 3 realys with the m50 harness, th stock e30 fuse box stays with the car.
        if you have a complete e36 m50 wiring harness you have all you ned
