Gauge cluster support interchangeable?
  • royalflush313
    • Mar 2004
    • 2070
    Just wanted to make sure that gauge cluster support is interchangeable between all e30s, or i have to get a specific one for a 318is. thanks.
    ~ Go Canucks Go! ~
  • reelizmpro
    • 9543
    Not sure what you mean by "support" but yeah the gauge clusters are interchangable.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • royalflush313
      • Mar 2004
      • 2070
      by support, i mean the part with holes that hold the gauges.
      ~ Go Canucks Go! ~
      • James Crivellone
        Head Janitor
        • 6305
        If you look at the Service Indicator lights then that is how you tell
        if it has 3 red lights, then only those can be interchangeable, if it has 1 red light, then those are interchangable.
        you cannot swap parts between the two, except for fuel and temp gauges, plus lightbulbs and shit
        • DanGillan
          • Mar 2004
          • 4061
          no.... not all clusters are interchangeable, if you had a VDO cluster, you need another VDO cluster, if yo had a MOTOMETER cluter you need another MOTOMETER cluster, dont post information if you dont know what your talking about.
          Dan
          • James Crivellone
            Head Janitor
            • 6305
            Clusters with teh coding plugs are interchangable, VDO or Motormeter, same with the earlier ones, same concept.
            don't post information if you don't know what your talking about.
            • royalflush313
              • Mar 2004
              • 2070
              well I have vdo, and mine is a 91 318is. How do i tell if i have the 'coding plugs or not?'
              ~ Go Canucks Go! ~
