E30 Clutch write up. where?
  • E30godz
    • 1524
    Is there one out there? Im just guessing that the slipping of the clutch has something to do with the additional power of the turbo but....yea. So i need a replacement. I was thinking of getting the IE/TCD racing clutch disc and pairing it with the stock pressure plate and throw out bearing.
  • Axxe
    • Aug 2004
    • 3355
    You will likely need a stronger pressure plate aswell.
    Keep it slideways!!
    • E30godz
      • 1524
      the disc is designed to work with the stock pressure plate
      • Axxe
        • Aug 2004
        • 3355
        Alright then, but put in a new pressure plate, and all clutch components. What kind of right up are you looking for? Installing the clutch? Bentley covers it quite well.
        Keep it slideways!!
        • Digitalwave
          is a poseur
          • 6299
          http://www.pelicanparts.com/bmw/tech...ch_Replace.htm
          RISING EDGE
