I just picked up another 325e that has low mileage but it has been parked for quite a few years. I have flushed the tank and filled with fresh gasoline, changed fuel pump, fuel filter, and relays. The car will start but only run for a second or two. Once it has been started three or four times It will not start again until it sits for a few minutes. I unplugged the cold start injector and it will not start at all. So it seems that it is only getting fuel from the cold start injector. I've tried quite a few ideas so far but nothing has shown any results. I would really appreciate any help that I can get.
325e Injector/Fuel Problem
Hi, from Chile, new on the forum, new on Bmw´s, got a 83 323ia
had exactly the same problem (the car will start but only run for a second or two. Once it has been started three or four times It will not start again until it sits for a few minutes), can´t find solution. Any findings?
Appreciate your helpComment
you can't see an injector pulse on a volt-meter, they pulse too fast.
check the injector harness connections (under the intake mani)1989 cirrisblau-metallic 325iComment
Relay huh cool!
1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)Comment
