Need help !
  • BmwEvoSport
    • 59
    Need help !
    Ok this weekend i installed a new dash and ever since my gas Gauge stopped working , i checked it with 3 other ones , what do i need to look at next?
    Thanks.
  • HST
    • Jan 2006
    • 757
    What do you mean that you checked it with 3 others?
    Originally posted by KingB
    Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
    • Nicademus
      • 2912
      Thanks.
      I did the same thing but now my speedometer doesn't work. Are you sure you hooked all the wires back up or didn't forget some? I'm finding that I did and its sucks. They came undone while I was removing things and since I never took them off myself or noticed them, they were never labeled or taken inventory of. Sucks :(
      Explain your situation better.
      Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
      ~ John Adams ~
      • SpecM
        • Oct 2005
        • 4531
        yea... three other gauge clusters?
        1989 cirrisblau-metallic 325i
        • BmwEvoSport
          • 59
          Yes i have two cars here and 4 clusters , in the other car it works fine , in the one car it dose not , it was working befor and i checked all the plugs to make shure i hocked everything back up and its all there. i dont know if there is a relay or if i need to go to the pump and check the float so im checking to see if anyone had this problem.
          • SpecM
            • Oct 2005
            • 4531
            sounds like a sending unit problem
            • Ray Smoodiver
              • Jun 2004
              • 8809
              Paging john and criv...
              • HST
                • Jan 2006
                • 757
                My vote is a bad sending unit.
