Dyno runs today
  • brodee
    • Jan 2004
    • 2914
    Dyno runs today
    finally got the car on the dyno. Max HP was 144.8, torque 140.4. I'll post the graphs later.
    The car is running VERY lean, A/F ratio was about 4 points off. I need to crank up the fpr about 2 more psi and try again.
    I'm a little disapointed, expected around 155 at the wheels but with it that lean who knows what it should run.
    Couple of pics......
    "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
    1988 M3 - Track Rat
    1989 325iC M50 Vert
    1989 325i Coupe
    1991 318is
    1995 318ti Club Sport
    2006 330i e90
    2008 Tundra Crewmax
  • Rob
    • 8166
    dont get caught up in the peak numbers, they are meaningless. look at the area under the curve for the performance of the engine, and the the air/fuel for tuning. sounds like you need some tuning, hopefully that will help
    BEERTECH
    • Jonathan M3
      • 1837
      what mods do you have?
      '05 E46 M3 Imolarot/Cinnamon - CURRENT
      '98 E36 M3 Estorilblau/Dove - SOLD
      '90 E30 M3 Brilliantrot/Black - SOLD
      SRS BSNS Motorsports - 24hrs of LeMons Racer
      • brodee
        • Jan 2004
        • 2914
        Dinan chip, 272 cam, intake, headers, custom 2.5" exhaust. 156k miles on the bottom end.
        1988 M3 - Track Rat
        1989 325iC M50 Vert
        1989 325i Coupe
        1991 318is
        2006 330i e90
        2008 Tundra Crewmax
        • Rob
          • 8166
          I think those numbers would be about right for a stock m20 on a dynojet. i *think*
          BEERTECH
          • brodee
            • Jan 2004
            • 2914
            I think stock should be around 134 at the wheels factoring an 18% loss.
            1988 M3 - Track Rat
            1989 325iC M50 Vert
            1989 325i Coupe
            1991 318is
            2006 330i e90
            2008 Tundra Crewmax
            • brodee
              • Jan 2004
              • 2914
              Here's the chart.. Click it for a larger version.
              1988 M3 - Track Rat
              1989 325iC M50 Vert
              1989 325i Coupe
              1991 318is
              2006 330i e90
              2008 Tundra Crewmax
              • SpencerM3
                • Aug 2004
                • 114
                WOW, thats lean. Looks like 16:1 around 5500.
                Any noticible detonation?
                • brodee
                  • Jan 2004
                  • 2914
                  none that I've noticed. As soon as I get a guage on the regulator I'm going to pump it up a little at a time and see what happens.
                  1988 M3 - Track Rat
                  1989 325iC M50 Vert
                  1989 325i Coupe
                  1991 318is
                  2006 330i e90
                  2008 Tundra Crewmax
                    • 34839
                    maybe some larger injectors would help out. do you have any vaccum leaks?
                    • brodee
                      • Jan 2004
                      • 2914
                      That's not a bad idea. What size are the stock m20 injectors?
                      1988 M3 - Track Rat
                      1989 325iC M50 Vert
                      1989 325i Coupe
                      1991 318is
                      2006 330i e90
                      2008 Tundra Crewmax
                      • mspiegle
                        • 1026
                        14# IIRC
                        Michael Spiegle
                        '01 Ford Escape / Daily Driver
                        '99 M3 / Track Car
                        '87 325is bronzit / wtf car
                        '06 Daytona Triumph 675 / Daily Rider
                        • brodee
                          • Jan 2004
                          • 2914
                          hmmm.. I might bump up to some 19.5# and see hos it handles that.
                          1988 M3 - Track Rat
                          1989 325iC M50 Vert
                          1989 325i Coupe
                          1991 318is
                          2006 330i e90
                          2008 Tundra Crewmax
                          • SpencerM3
                            • Aug 2004
                            • 114
                            Not sure if S50 injectors are compatible with M20 engines, but 95 M3's (maybe even 325's) have 17# injectors that can be found dirt cheap.
                            One step up from their are the 21.5# injectors in the 96-99 M3s.
                            • brodee
                              • Jan 2004
                              • 2914
                              I thought my '95 M3 had 21.5's in it, hmmm. I changed them out for 24# when I added the cams and hfm. Wish I had kept the old ones :(
                              1988 M3 - Track Rat
                              1989 325iC M50 Vert
                              1989 325i Coupe
                              1991 318is
                              2006 330i e90
                              2008 Tundra Crewmax
