power window problem
  • lennon
    • Jun 2008
    • 1416
    tonight when i went for a drive my power windows no longer work on either side. no noises or anything, just acts like the switches arent even doing anything. the windows worked fine earlier today. replaced the fuse, thats not the problem. i was wondering if anyone has any ideas on what might be wrong before i just start tearing into stuff.
  • george graves
    • 20003
    Did you accidentally press the windows lock out switch?
    Originally posted by Matt-B
    • lennon
      • Jun 2008
      • 1416
      what the hell is that??
      • Nicademus
        • 2912
        Sounds like my car :(
        Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
        ~ John Adams ~
        • lennon
          • Jun 2008
          • 1416
          it really sucks because theyre stuck down and it rains all the time here.
          • lennon
            • Jun 2008
            • 1416
            bump for a cold night and still no windows
            • ADEN
              • 620
              If the switches lights aren't working then the lock window switch or a blown fuse.
              • CrazyGhost
                • Apr 2007
                • 24
                Happened to me. As far as i can remember if you turn your head lights on and the power window switches are not illuminated then there is a issue with the safety switch in the dash. Rip it out and make sure all the plugs are connected properly. As for the windows being down get out an allen key, remove the little plug in the door and wind it up manually.
                • lennon
                  • Jun 2008
                  • 1416
                  my power window switches arent illuminated, the up and down arrows are just painted on or whatever. and i replaced the fuse already, it didnt change things. what is this window lock you guys are talking about? never heard about it
                  • jamiholzbach
                    • 311
                    lockout switch
                    On most E30's its above your radio next to your hazard light switch, on some cars its on the center console next to your window switch(on my '87 its above the radio, on my '89 its on the center console).
                    • lennon
                      • Jun 2008
                      • 1416
                      wow i feel stupid now. i guess someone (i dont think it was me) pressed that lockout switch. i never knew what that button was so i never mess with it. im so glad something wasnt really wrong! thanks for the help guys
