help using helicoil's
    Alright, i read most, never post. but here is what im faced with.
    i have two stripped threads in my block.
    one M6x20
    and
    one M6x30
    what would i have to do to get a helicoil to work? i went to the parts store and they only carry a M6x1 kit. nothing else. its also 40 bucks a pop, and i dont want to buy two kits for two different measurements.
    is there such animal as a M6x20 and M6x30 helicoil? or is the M6x1 a one size fits all?
    An M6x1 helicoil refers to the thread diameter and pitch, but I think your M6x20 and M6x30 are referring to the diameter and length. Those tapped holes are probably 1.0mm pitch as that is the most common for an M6 bolt. A standard M6x1 helicoil should work in both cases.
      Use Time-certs! Much better product, you will be happier with the installation and results.
        i have seen this on youtube, but it looks the same as a helicoil, no?
          If you use the term loosely, like a chevette is the same as an e30. They're both cars right?
            So long as it is done properly... I just had a time cert fail, fucking sucked.
            Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
            Help a brother out, buy your detailing products here...
              Recoil is the way to go. Get a whole kit, comes with the bits, installation tool, extraction tool and the recoils needed.
              1985 325e 2.8 Turbo VEMS
                i read that this is a issue that comes across often, and i would not want to do more damage than there already is
                i am going to search around town for a kit thats cheaper than $35-40 bucks for a bit, a tool and 4 little helicoils...
                sound smart at this point to helicoil every hole on the thermostat housing and waterpump section? 7 bolts total, and i am thinking about upgrading to a higher quality bolt as well....
