Cabrio third break light How the hell do I replace it?
  • parkerbink
    • Jun 2004
    • 10137
    There are no obvious screws, no access from inside the trunk (tool kit is right under it)
    edit:
    I found the four screws hidden under the foam above the tool kit but it still won't come off.
    Bulb died & the check panel light is driving me crazy!
  • parkerbink
    • Jun 2004
    • 10137
    Anybody?
    Help
    Por favor!
    • NC325iC
      • Mar 2004
      • 6565
      open your trunk open the toolbox there are i think 4 screws on the decklid and i think the top just lifts off when you get them all off
      • parkerbink
        • Jun 2004
        • 10137
        I did and it's still connected somehow and I prefer no light to damaging it.
        • Xuon
          • Aug 2004
          • 128
          yo la reemplace en mi cabrio, deja recordar como por que ya no lo tengo :x
          • parkerbink
            • Jun 2004
            • 10137
            Claro que si!
            Gracias!
            • Nate325ic
              • 462
              eh just get rid of it with a sedan/coupe trunk lid
              • Nate325ic
                • 462
                what year is your cabrio. I think the 3rd brake light assembly came in 3 different forms through out the e30 cabrio lifespan. and each might be a little different. mine has 2 screws on the lense that give me access to the light bulb
                • parkerbink
                  • Jun 2004
                  • 10137
                  • Nate325ic
                    • 462
                    so you have the really slim low sitting brake light right?
                    • parkerbink
                      • Jun 2004
                      • 10137
                      I guess, I will take a picture 1 minute
                      • parkerbink
                        • Jun 2004
                        • 10137
                        I found & removed the four screws hiding under the foam the toolbox compresses into & it's still connected to something alittle behind the middle going toward the back window.
                        Thanks
                        • NC325iC
                          • Mar 2004
                          • 6565
                          ok just a sec let me run out to my car
                          ok there are a total of six screws
                          4 inside the tool box and then two more below it
                          if youu look inside the two holes the trunk below the tools there are screws in there
                          • parkerbink
                            • Jun 2004
                            • 10137
                            Thanks!!! its the two hidden inside the holes at the back of the trunklid & the two at the back of the tool kit. I got it out, it's the same fitting as the marker lamps (I put one in I had) but the bulb part is bigger and more watts. Anyone know how many watts it is? It's unmarked.
                            • jblack
                              • Aug 2004
                              • 98
                              I don't know, but it is part number 63-25-1-372-632, if you want to go to the dealer....
