Replacing Right Passenger Window - Edited
    1991 325i Two-Door.
    Got the window, so where do I take the panel off of? Anyhting need to know about the power and little mechanisms?
    I did do a search and found out how to replace rear window.
    Thanks.
    Also, how do I exactly get the seat out?
    Please?
      Kinda useless if I can't get the window in. Somebody has to know?
        I got the same response when I asked this question.
        You need to remove the entire mechanism, then put the window in, then replace the mechanism in the door without bolting it in, get the wheels in the runners on the window & bolt the mechanism in.
          ActuallyI did it way different. Instead of taking more than the panel off, you take the two bolts on the right side that hold the right arm. Than you side the left part onto the track and with your hand move the right track around til it gets on. Than bolt. Moving the window up and down is neccessary many times. So yep, time to fix glove box.
          ty guys.
