Fuel pump help.
  • E30SPDFRK
    • 5695
    Bump again, I have used up all of the in tank pumps in the junkyards around, lol.
    Byron
    Leichtbau
    • hendrixvodu
      • Jan 2007
      • 2514
      bump...he needs a pumpski!
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
      • bmw325csi
        • May 2007
        • 4045
        My car did the same thing for a while, but lucky for me it was the wire thats connected to the positive terminal on the battery, my battery slid from its place while going up a driveway and the wire ripped off, I went threw about 3 used pumps and 2 new ones, in the end i soldered that fuckin wire in place and viola.
        This might not really help you b/c you have a early car, but its worth a shot. BTW I have a nice fuel pump for a 325i with like 12 miles on it if anyone needs a bargain pump.
        harry/harout
        • E30SPDFRK
          • 5695
          Bump again
          Byron
          Leichtbau
            A used pump is an iffy proposition, at best. Spring for a new pump, but before installing it, make sure that you aren't killing pumps from a build up of sediment (rust actually) in the tank.
            • E30SPDFRK
              • 5695
              There is no sediment. I don't want to buy a new one until I find the problem though- $15 is easier to lose than $250.
              Any more help on converting to a late model pump? I got one from FredK last night but it has no return line on it. Where does the return go on late models?
              Byron
              Leichtbau
              • E30SPDFRK
                • 5695
                Byron
                Leichtbau
                • E30SPDFRK
                  • 5695
                  bump
                  Byron
                  Leichtbau
                  • Philo
                    Ich esse kleine Kinder
                    • 3334
                    No clue on conversion, but your pumps might be dying due to a build up somewhere in the system making too much stress on the used pumps. good luck with the struggle. keep posting any new findings. i'm interested to find out the prognosis.
                    -tim
                    Originally posted by Jordan
                    I like the stance
                    • E30SPDFRK
                      • 5695
                      Yeah, I think it is the outside pump that is holding it back. I'm going to a Junkyard in Mass tomorrow to try to find both pumps, and if they die I am just gonna put in a late model tank and skip making a new line for the return.
                      Byron
                      Leichtbau
                      • FredK
                        • 14761
                        It looks like it goes to a nipple on the driver's side of the tank in the attached drawing. #2 is the return line, #1 is the supply line.
                        • E30SPDFRK
                          • 5695
                          What the hell, I looked on realoem and it showed the same pic for late models as it did for early models. I tried to trace the line in the 318, but it went up and over the tank.
                          If the new pump I got today doesn't work, I may need your tank as well, Fred.
                          Byron
                          Leichtbau
                          • FredK
                            • 14761
                            My tank has a pinhole in it. I think it can be repaired, but I tried using that kneadable epoxy stuff and it started leaking again.
                            • E30SPDFRK
                              • 5695
                              I finally got a working pickup pump in long enough to test the fuel flow coming out of the return. Bentley says the spec is 30oz in 30 seconds- I got 7oz.
                              I changed the main pump with another used one, but that one didn't work at all. I was only getting 9 volts at the main pump, is it supposed to be that low or is there something wrong with my pump wiring? I suck at electrical.
                              Byron
                              Leichtbau
                              • Todd Black 88
                                • Oct 2007
                                • 3449
                                Originally posted by codyep3
                                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                                2001 silver/Blk 325 cabby. SOLD
                                2002 325xit Sil/blk. SOLD
                                2010 F650gs twin
