Need help!!!
  • euromk2
    • 4
    Need help!!!
    So i was worrking in my engine bay and my prybar accidentaly hit the contacts on my starter! It made quite a spark! So i checked the starter fuse right away! It was fine, so i thought ok its fine! When i went to start the car, it wouldnt! The starter clicked but did not turn the engine over. I tested my starter and its fine. The fuse is not blown. Anyone know what has happened? What should i do?
  • M5wanaB
    • Aug 2007
    • 405
    is there a fusable link there?? might have to replace it. other than that it sounds like your battery is a little low, give it a charge or jump start it and see if it cranks.
    1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
    • euromk2
      • 4
      My battery is fine fully charged! Fusible link where?
      • E30_fiend
        • Apr 2006
        • 7348
        If its a 5 speed, bump start it. The starter might be stuck in a position it doesn't like. Or just give it a good smack with a mallet or something to see if you can jar it.
        This should be a lesson learned. The manuals don't say disconnect the battery before any repairs for nothing. Its just a precaution so something like this doesn't happen.
        Taylor
