Someone Please help, I am running out of ideas.
  • BE30s
    • 85
    I have shimmy on my steering during breaking and once in a while even while driving on a straight road. I changed my rotors and pads up front thinking I have wrapped rotors. Unfortunately that was not the problem. I changed my tie rods control arms and bushings along with the strut mount up front and I still have the problem. What else can it be, I am really running out of ideas and it really annoys me especially after all the money I spent lately thinking it would fix the problem.
  • mjc85
    • Mar 2004
    • 164
    Maybe a weight missing on your wheels, check them out, if not that you may need your wheels balanced again. My car was doing it at about 50-60mph but it was just a weight missing off the front left wheel.
    1990 318is Brilliantrot
    • e30evolution
      West Werks
      • 1888
      wheel bearings.... ball joints
      http://www.westwerksauto.com
      • BE30s
        • 85
        The left side wheel bearing has been replaced. As for the ball join, isnt that in the control arm itself because that has been replaced.
        • BahnE30
          • 1050
          something in the front end is loose somewhere's along the way....
          re-tighten everything...
          chances are if it's a wheels weight it would be there whether or not you were braking...
          • bimmerboy12
            • Jun 2004
            • 1057
            here ya go..
            try switching your back wheels with your fronts, and see if the shimmy goes away. Could be a seperation in your tire, or a broken ply.
            1988 325iC Project - FINISHED!
            Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
            • Rob
              • 8166
              balance all 4 wheels and tires, thats a cheap solution that should be done anyway
              BEERTECH
              • bimmerboy12
                • Jun 2004
                • 1057
                switching the backs with the fronts is cheaper and faster and will not solve, but narrow down the problem.
                • Spaz
                  Crazy Canuck
                  • 2276
                  you should do this every so offen anyhow, as your tread on your tires wears down, it throws out your balance ;) just incase you didn't know.
                  Cam .W '91 325is
                  Spaz's 1991 Alpine White???? S52 Build Thread...
                  • Rob
                    • 8166
                    BEERTECH
                    • NC325iC
                      • Mar 2004
                      • 6565
                      Re: here ya go..
                      if the problem is a wheel that doesnt get rid of it it just shakes the back of the car instead
                      • BE30s
                        • 85
                        Thanks for all the input people, I'm going to get my rotors resurfaced and tires balanced and an alignment done tom. I will let you guys know the outcome just incase someone runs into the same type of problem in the future.
                        • e30Matt
                          • 5077
                          Re: here ya go..
                          That's how you find out if the wheel is the problem. :)
                          • bimmerboy12
                            • Jun 2004
                            • 1057
                            Re: here ya go..
                            at least someone got it... ;)
                            • BE30s
                              • 85
                              Can the steering rack cause shimmy, I had it replaced with a remanufactured one about a year ago and it not leeking at all.
