Hi,
I recently purchase an 89 325is track car. The MotoMeter cluster's odometer doesn't work, although the speedo is fine. Checked the gears and they were fine, so I suspect something else wrong w/ the odometer electronics.
The motometer itself was a replacement for the original VDO unit. The PO just threw the MM in to replace the VDO rather than pull it apart. In looking at the VDO (he gave me as a spare), the gears are definitely shot...have a replacement set on the way right now.
Is it possible for me to just put the VDO speedo/odo into the MM cluster? Not sure how interchangable they are. Since I know everything else on the MM cluster is working, wheres the VDO I'm not sure about, if the parts are definitely interchangable they I don't have to worry about pulling it again.
Anyway, anyone tried swapping the individual components?
Thanks,
Chris
PS - 1st post.
Thanks,
Chris
PS - 1st post.
