Headgasket &...
  • ThePotsy
    • Jul 2008
    • 210
    Headgasket &...
    What else?
    Anything else I should replace since I'm pulling the head? Timing belt for sure.
    "Our mother of blessed acceleration don't fail me now."
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Water pump, buy a full top end gasket set if you can, clean, and reseal anything you open correctly. get a crank seal, t-belt, plugs, (Headbolts?) cooling system hoses, t-stat, and spraypaint. Lots of spraypaint.
    • ThePotsy
      • Jul 2008
      • 210
      Crank seal or cam seal?
      Going to do a valve adjustment as well. New eccentrics and bolts.
      Also, I seem to have developed a leak from the top of the tranny, I assume this is the shifter gasket? Checked the vent and it's fine, doesn't seem to be coming from the seals.
      • DCColegrove
        • 2748
        Head bolts for sure, they are "torque to yield" and as such a one shot deal.
        Torque sequence= 25 ft lbs- 90 degrees- wait 20 min another 90 degrees (some manuals have it incorrect)
        note: Do not put any thing on the drain tube except for the o rings and a little grease on the lower one... it will leak if you try to "glue" it in.
        more questions? PM me.
