What kind of Power steering fluid?
  • apm
    • 245
    I need to fill up the power steering fluid because I changed the hose and lost some in the process.
    What is a good PS fluid out there for an E30 M3?
    • 34847
    ATF dexron/mercon. I usually get royal purple because it's synthetic, available locally and not all that expensive.
    • DCColegrove
      • 2748
      Nando is correct ...
      I would add that the fluid should be changed very often the system holds less than a quart and the fluid breaks down rapidly.
      I change mine and all my regular service customers at every oil change.
      Doing this... I have never had to reseal or replace a rack.
      • apm
        • 245
        so just ATF Dexron? No numbers or weight or anything like that? So I need to get a synthetic Power steering fluid?
        • SpecM
          • Oct 2005
          • 4531
          I think it's Dextron III ^
          1989 cirrisblau-metallic 325i
          • DCColegrove
            • 2748
            As long as it is DEXRON (no T) you will be fine.
            • M3 Ryan
              Site Sponsor
              • 2298
              And it doesn't have to be synthetic, but it is nice to have. I suck all the fluid out of the resivour and replace it every oil service (after doing a major flush on the particulat car already). It is cheap and can save you leaks.
              Also, if you have a leaky rack/hoses, try some Valvoline MaxLife ATF With StopLeak in there, I have seen racks go from leaking 1qt every day to no leaks at all after one qt of the MaxLife, it really works!
              '88 M3.2 S54 Lachssilber/Black
              '07 335i Alpine/Black Sedan
              '12 X5 3.5i Alpine/Black
              iS Splitters For Sale, PM ME!
              • Kingb
                • 928
                I learned the hard way and put PS fluid while my rack was leaking and it ate up my pump and I still had to replace the rack. Leason learned
                Originally posted by Nicademus
                My car beats off to that car. :bow:
                • apm
                  • 245
                  so I bought some PS fluid leak stop yesterday. Do I need to tap it off with half Dexron and half PS fluid leak?
                  Right now I'm using all PS fluid stop leak and no Dexron at all, and I noticed some weird sound when turning the wheel.
                  I think something is not quite right here. It still works but I don't like the sound of it. Will it take a while for it to settle down?
                  • JAM
                    • Feb 2007
                    • 524
                    dont use that shit, are you high? if something is broken replace the part.
                    you should only be putting atf in you powersteering fluid res
                    Originally posted by Mr Watsonsilver
                    driving boards?
                    • apm
                      • 245
                      Yeah I already have Dexron ATF but I'm jus trying what he suggested.
                      See below..
                      • StereoInstaller1
                        GAS
                        • 22679
                        WTF, I just looked at mine yesterday. It looked pretty nasty, and is fresh from last spring.
                        Does it really get that hard of use? I am gonna listen to the techs here and consider it part of an oil change.
                        What should I use to suck it dry? I don't have a suction device, would gravity draining be OK? Where should I drain from?
                        Thanks, guys.
                        Luke
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • JAM
                          • Feb 2007
                          • 524
                          iirc there is a hose clamp that connects the reservoir to the pump, i think that would be your best way of draining it.
                          driving boards?
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            Or, get a nifty vac suction pump from HF.
                              • 34847
                              Thanks, guys.
                              Luke
                              turkey baster, 99 cents at walmart :p
