whats causing this> any ideas?
  • blunttech
    • 12850
    its my 88 325is. its basically got new everything. it runs perfectly 99% of the time. in fact this has only happened 3 times . i never really beat on it but if i run it up to 6500 or so once in a while it will just shut down for a split second, the check engine light will come on and then it will resume running perfectly again. as soon as it cuts out my automatic reaction is to take my foot off the gas . the car never dies, it just picks up like nothing happened and no check engine light or anything. runs great otherwise. any ideas??
    i built this car for my dad and replaced almost everything a couple year ago. car has maybe 8k on it since then. so everythings fairly fresh
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
  • OrganicMechanic
    • Jan 2008
    • 1719
    crank sensor?
    join the E30 Cabrio owners gruppe
    click here for details
    • Julien
      • 7472
      Hey sweetie,
      Had the same problem with my 88 325is, but it occured around 4-5k RPM. It turned out to be the TPS that was not adjusted properly, I say swap an entire assembly TB to test it.
      XOXOXOOXOXOXOOXOXXO
      Joo
      Build Threads:
      • vivalegreg
        • Apr 2006
        • 1313
        what about your main relay? or fuel pump relay? sounds like some crazy electrical mess up to me...had this happen on my ix and my m10....it would just cut on and off like power was there, then not, then there then not...but happened more frequent then your problem? do you feel like that is what the car does when this occurs?
        e30s r kool
        • blunttech
          • 12850
          Originally posted by Julien
          Hey sweetie,
          XOXOXOOXOXOXOOXOXXO
          Joo
          its quite possible its happening at 5k. in my old age i feel like im going faster than i really am. i will swap out a tb to test . thanks for your wisdom in this matter.
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • blunttech
            • 12850
            this is more of a once every few months type occurrence. sometimes it goes thru the full rev range with no issues. i think its what joo said. thanks
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
              If the CEL is flashing on, there will be a stored code. That code may provide a clue as to what's happening. Have the car scanned by someone with the proper diag system (dealer or well equipped BMW indie shop).
              • DCColegrove
                • 2748
                I might suspect a dead spot in the AFM...
                Pull the codes if you can...
