e30m50 starter question
  • Brew
    • 3060
    First off, I'm using the m20 starter with the getrag 260 and m20 clutch and flywheel. I have 4 wires connected to the starter, a red power wire, a black wire going to the alternator, a black and yellow wire, and a black and green wire. When I turn the key to the "on" position, the starter makes noise but does not turn the engine. Am I fucked?
    '91 318is
  • Jordan
    • 12911
    sounds like it is improperly wired.
    https://mtechniqueabs.com/
    • Brew
      • 3060
      Well the starter is getting power and its getting a signal from the ignition to turn on. I am really really worried that my engine might be seized or something. To me, it almost sounds like the starter is trying to spin but can't for some reason. I might be planning a trip to Maine where I bought the motor.
      '91 318is
      • UNHCLL
        • 8789
        Pull your spark plugs, put the car in neutral and spin the engine over by hand. Thats the easiest way to tell if the engine is siezed.
        i think you'vr got wires crossed.... :?:
        Below the radar...
        • Brew
          • 3060
          Thanks Chris, I'll try that. I'm hoping its just a wiring issue.
          '91 318is
          • UNHCLL
            • 8789
            I'm sure you know, but only spin it in the direction of rotation while running. let us know how the manual crank over goes.
            Below the radar...
            • Brew
              • 3060
              Stupid question probably, but which way is that? :oops:
              '91 318is
              • UNHCLL
                • 8789
                Counter Clockwise if you are looking head onto the engine from the front IIRC.
                Double check that though!
                Below the radar...
                • Brew
                  • 3060
                  Looks like I'm taking a drive. :curse: I don't think I've ever been so pissed in my life.
                  '91 318is
                  • Jordan
                    • 12911
                    Wait a sec... are you to tell us you didnt try to turn the motor over prior to buying it?
                    That sucks.
                    • Brew
                      • 3060
                      I thought that I had turned it at some point. The motor was on a stand when I picked it up but the kid assured me that it ran well. Hopefully I'll be able to work something out. I feel like such a fucking idiot. Can you delete this friggin thread? I don't want to look at it
                      '91 318is
                      • Jordan
                        • 12911
                        So you took the plugs out and attempted a hand crank over with the front main crank bolt to no avail? engine wouldnt budge?
                        • Brew
                          • 3060
                          Yup. I pulled like a mother fucker. And yes, the tranny was in neutral.
                          Is there any other reason why it wouldn't turn?
                          '91 318is
                          • trent
                            Yea, a rod is melted to the crank.
                            • Brew
                              • 3060
                              Fuck.
                              I have so much violence in me right now.
                              '91 318is
