Hub problem after track day
  • nzer
    • 122
    I haven't been driving my car much since a recent track day - but i've noticed a mean knocking coming from the back when you change between going back and forward. So i whipped off the rear wheels and had a look.. well - the right hand hub is able to move some degree around its drive axle - does anyone have a detailed diagram - could it have sheared a few splines?
    pic - if i hold the middle bit.. I can move the disc around hub around it a few degrees.. it makes the same knocking sound. I would have thought the wheel bolts would have stopped that movement - so maybe the knocking is coming from inside the hub.
    any ideas?
    thanks
  • surebimmer
    • Jan 2004
    • 978
    Got any wheel bearing type noise going on? If the bearing is shot there would be your play.
      • 34844
      I bet it's the bearing. mine are shot too, and I also have a knock noise under certain transistions. Mine will be replaced this month, hopefully that noise will go away and my car will be quieter :)
      • nzer
        • 122
        no grinding noise if thats what you mean - everything is pretty new on the car, its only done 2700 miles now since it was built.
