How to change foglight bulb?
  • Chris E30 Cab
    • 866
    Could someone enlighten me on how to change the fog light bulb.....for the life of me, I cannot figure out how to get the fog light out :evil:
    Thanks, and by the way it is for the late model fog lights.
  • reelizmpro
    • 9558
    You don't remove the foglight. There's a little cover on the bottom of the housing secured by screws. Remove the cover and that's it.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Mystikal
      Wheel Fitment Expert
      • 9602
      There are 2 ways, either remove the entire assembly by removing the bottom rubber plug on the lens, taking out that screw (no need to touch the top one), and pulling the lamp out, or go underneath and remove the round cover by removing the 1 screw and reveal the bulb. Note that once you take the assembly out (option 1) you will still need to remove the 1 screw at the bottom. The only incentive to removing the entire lamp is that you won't need to jack your car up to get underneath.
      • e30Matt
        • 5077
        I changed mine just fine w/out jacking the car up... I had to remove the 'is lip, though.
        • Mystikal
          • 9602
          I have a big head, and he has an M-tech II valence. No removing anything to help him.
          I also got under mine at stock height with the is lip on. Heh.
          • Chris E30 Cab
            • 866
            Thanks fellas....I suppose the biggest problem is just bein able to look up under that front spoiler.
