I took my AFM/Airbox off my intake boot, and there was quite a bit of a light brown liquid in there... the color of chocolate milk. It was enough to fill the bellows of the intake boot and run out. It looked like it was sprayed from the intake side towards the AFM. Keep in mind it is about 10 degrees out and I just had pulled it in to an 80 degree garage an hour or two before. Any ideas? I may have seen some water bubbles in it too.
Chocolate Milk in my Intake Boot...
Tags: None -
ice mixing with sludge = chocolate milk umm does the body good...
1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car) -
You should look at your oil and coolant too... chocolate milk is not so good. Head gasket or maybe worse...Originally posted by chileelkyamaze about the enthusiasm e30 generateComment
It is in the intake boot...
He said that it is 10deg out which will cause freezing
1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)Comment
yes that is why they make Throttle body heaters duhhhhh lol To eliminate freezing
and since our e30 dont have a oil catch can oil residue coats the inside of the intake system which has mixed with H20 and caused the brown ness
So any updates OP?
Only reason for that would be if the crankcase vent was messed up. There is no way that that sludge should even be in that large of a quantity, much less in the intake boot.Comment
hey your back so how does your oil and coolant look?
I'm not entirely sure on the M20, but it will be coming out of a high point on the cam cover, possibly under the intake manifold. It will run to a point just aft of the throttle body on the intake manifold. The entire idea behind it is that during ignition, a small amount of pressure escapes around the piston rings. That pressure needs to go somewhere, so it is routed back into the engine to be burned. This helps to a small degree with air metering, but, more importantly, it burns up the inert oil-air mixtre from the innards of the engine. If your engine has too much blowby (i.e. bad piston rings) an excess amount of oil and air may be travelling through the crankcase vent, or PCV, valve. A leakdown test is all that is needed to check this.Comment
My oil looks fine. I just replaced the T-shaped heater hose, so saw a lot of coolant and it looks fine since I did the flush this past summer.
I am wondering if the inside of the intake just "sweat" a lot when coming in from the cold into a hot environment. From what I have read elsewhere, some oil in the intake boot is normal.Comment
