I was driving home from work tonight, and realized that my car was overheating. I pulled over, opened the hood and coolant is all over the place on the reservoir side and no coolant was in the tank. I got her home slowly, got it in the garage to see what the problem was.
I clean all the coolant mess and put water in the reservoir and started it up again. I got it up to temperature and it maintained to be cool the entire time I had the engine on. I notice the only leak was coming behind my driver's side wheel, right underneath by the lollipop.
I was thinking it might be the heater core since it is cold as balls outside and I have been running the heater, but there is no leak inside the cabin.
Any ideas what it is? My waterpump is brand freaking new, fan clutch is good, radiatior is good, and no leaks anywhere else other than behind the driver's side wheel.
Much help would be GREAT!!!
~Mitch
~Mitch
