hit a bump.. got a flicker.. then lost cluster lights and OBC lights w/headlights on
  • houstonh
    • Aug 2007
    • 293
    Everything seems to be working fine except I have a pitch black cluster and OBC at night.
    I have checked fuses and see any blown.
    Also noticed my ashtray lights aren't on.
    Any ideas?
    anyone seen this before.
  • SamE30e
    • Sep 2007
    • 4319
    Short somewhere.
    1985 325e 2.8 Turbo VEMS
    • sticksdaman
      • Apr 2005
      • 2987
      Not being funny, but did you try hitting another bump? Ive had this happen before and sometimes all it takes is a solid thwack to the dash and everything comes back on.
      Originally posted by ebelements
      Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
      • E30SPDFRK
        • 5713
        Any ideas?
        This actually just happened to me too, except I didn't hit a bump. I changed my cluster and they all died, so there must be something loose back there.
        Byron
        Leichtbau
        • houstonh
          • Aug 2007
          • 293
          Originally posted by SamE30e
          Short somewhere.
          Any idea where I would start? I am trying to figure out what connects ash tray, cluster, and obc lights together.
          seems like there would be something simple, but I am not finding much help with the Bentley (as usual)
          Does anyone know of a relay or perhaps a direct fuse that I should examine more carefully?
          • Bimmerista
            • Nov 2005
            • 5425
            Houston...how is the connection behind the cluster? Does the OBC still work or it just the light bar thats out?
            • houstonh
              • Aug 2007
              • 293
              Checked the connections last night.. replaced the cluster lights despite my doubt that it was the issue.
              Also the lightbar is fine as it is still super bright when the lights are off. Once the headlights turn on it goes dim (black at night)
              Is there a relay for the cluster lights/dimmer/ashtray lights? It seems to be most if not every interior light that is effected when the parking or headlights are turned on.
              • einstein57
                • Jun 2007
                • 10780
                battery terminals on tight?
                www.gecoils.com
                • mikeedler
                  • 6707
                  ground, or possibly the headlight switch itself. prob. the switch though.
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    Fuse 23, Is it getting power?
                    -Dave
                    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                    Need some help figuring out the ETM?
                    • brandondan1
                      • 1091
                      Yeah, check the headlight switch. It acts as a fuse itself, and if the dimming feature didn't work smoothly before (lights cut on and off while turning the knob) it could be the problem now.
                      91 318is
                      • houstonh
                        • Aug 2007
                        • 293
                        Will try swapping switches with my beater and report back.
                        also will take a closer look at 23.
                        Brandon... please make it warmer here. This weather SUCKS!
                        • houstonh
                          • Aug 2007
                          • 293
                          Light switch it is.
                          put the one in from the beater and it worked.
                          • mikeedler
                            • 6707
                            ha ha damn I'm good sometimes!-- actually that was the problem on one of my cars last year or so.
