I did a search and read up on it but where does the wire run from the front to the trunk? is it in side the car or on the underbody??
Moving battery to trunk
i did this in my cab, had to cut 2 1 inch round holes to route the wireYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
I routed to the hole where DME harness routes through firewall.
join the E30 Cabrio owners gruppe
click here for details
Cabriolets have a knock out oval hole in front of the glove box, on the right...right where the 6 bangers have the stock run.
LukeComment
Please document everything you do using pictures if you can. I wanna try this on my vert when I get a chance.
I was thinking of going to a junk yard, and remove the high gauge wire from one that has it in the trunk and simply retracing that back on my vert.
I figure it should not be a huge deal.
:DThis my spam training account. Do not send e-mails to this address.
spam.7xmo_fszol@hlmtechnologies.com
Thanks. :pComment
I will take pics when I go to do this. First the subframe is getting dropped to be rebuilt. I read somewhere that someone did this on their vert and ended up about an inch short to the Battery so they moved the block that the wire connects to in the engine bay over an inch or so. But they also said that if they did again to start in the trunk and work your way forward. Thats what I will do. Also their cables didn't come from a vert so the vert ones might be a little longer.Please document everything you do using pictures if you can. I wanna try this on my vert when I get a chance.
:DOriginally posted by NicademusMy car beats off to that car. :bow:Comment
'Verts have a front battery for a reason. The additional bracing on the inside of the car make it a fucking BITCH to run that cable.
I recommend you find a helper like this one:
If you look carefully, you can see the brace.
