My whole exhaust is starting to comedown. the converter is rusty and the pipes by the rear control arm are squeeshed half way. I got a dtm dual inlet muffler that i just got and put on there and ill probably use it in the new exhaust. My question is how big of piping to use, and should i use a converter or not? Here in Florida we dont have emmesion tests anymore so no cat would be no problem. Do m20b25 sound good with straight pipes?
Straight pipes on my 87 325is
Tags: None
there is no reason to run without a cat on the street. None whatsoever. Modern cats are higher flowing and less expensive than ever. But a universal cat from www.jegs.com or www.summitracing.com
Your car will get really loud without a cat btwBEERTECH
Yeah i know its gonna be way louder cuz i got straight pipes on my 98 328 and it sounds good, just wanna know if it sounds good on e30s.Comment
it's not going to make your car any faster...Originally posted by denisbmwm5The reason i want to run straights is performence wise.Comment
I know e9nine had straight on his former car.....not sure if he posted ckips, but I had the feeling it sounded 'dirty'. It might be loud, but probably will sound like SHIT.
I need to replace my cat sometime, but either high flow cat.....or would a resonator in its place work too?Comment
I drove my car for a day without the rear exhaust section, and I got a noise ticket ($40 CAD). Other than that it sounded wicked. At low rpm's it burbles like a race car, and at 6k rpm's it's way too loud. Can't listen to radio or anything, and I had a huge headache after an hour of driving.Comment
Originally posted by rwh11385I know e9nine had straight on his former car.....not sure if he posted ckips, but I had the feeling it sounded 'dirty'. It might be loud, but probably will sound like SHIT.
Well I bought his car and drove it for 8 hours, got a good idea of the exhaust sound. I liked it, with the stock muffler it wasnt too loud. Cant comment for the power changes
I do know a local guy added straight pipes to his built 2.8 stroker, got really loud, sounded good, and he says it pulls hard. but he has a balls out built motorBEERTECH
Yea i was thiking or using some sort of a high flow cat or resanator. what exactly is a rasanator? its build like a cat? or muffler? im asking jsut i never experimented on themComment
Cat:
Basically scrubs the exhaust gasses. has the side effect of quieting the exhaust noise.
A resonator is basically a smal hig flowing muffler, usually tube shaped, whose purpose is to reduce noise.BEERTECH
when rebuilding my car we started it with just exhuast manifold. IT SOUNDS ORGASMIC! it would sound like a true race car with just a straight pipe. Put if you put a cat back on it it might just sound raspy like something is broken, you either need to build an exhuast thats likely to be over 90dB or run a normal street exhuast.Comment
Hopefully mine wont be too bad. I have S52 headers and downpipes to a AA 3" collector back to a 3" Borla stainless muffler. And I am actually taking this from advice from a few S52 boys and the price was right....
Free! 8)Im now E30less.
sigpicComment
