e34 healights?
    e34 healights?
    will e34 headlights fit on an e30?
    can they be screwed into e30 headlight buckets to make them work?
    e34 ellips?
    Originally posted by Gruelius
      Brackets don't fit but lights are the same.
        the mounting tabs are farther out on the e34... cant say if it will still work or not.
          Re: e34 healights?
          Assuming you're asking about ellipsoid headlights- the answer is NO, they will not fit. Only the lens is the same, the body/reflector part is different (the mounting tabs are quite a bit different).
          Bret.
            Reflectors will fit I use them as replacement parts on e30 units that are broken. The mounting assy no not a chance.
              Werd. Only the glass is the same. The mounts are totally different on the light itself and on the carrier assembly.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
