The lights above the rear view mirror
  • MonthOLDpickle
    • May 2004
    • 107
    On the 325i 1991 BMW they have lights where it says Brakes Engine Oil and so on. Well my coolant one is on? What exactly does that mean? I already replaced the thermastat and put fresh coolant in. This was like two weeks before this light came on. Its been on for two days now. So whats up?
  • KDZROK
    • Aug 2004
    • 759
    have you checked your coolant level since the light came on? It usually means you NEED coolant. You might not have put enough in, or maybe forgot to replace the cap so some has spilled out? Or might have a leak now? Check your level. If the level is fine, I have NO clue.
    • e30Matt
      • 5077
      Have you checked the coolant level sensor? A lot of times these will go bad causing a coolant light that will never go away.
      • KDZROK
        • Aug 2004
        • 759
        That's good to know.
          • 37833
          BUT, since it wasn't on and now it is, it could be low coolant. Is your car still running at the same temp as usual?
          Grover Beach, California
          BimmerHeads.com
          • MonthOLDpickle
            • May 2004
            • 107
            Yes its running same temp. According to the scale its just past 2/4 from the left. =p Thats why I haven't gotten that worried. My lights tend to come on and off spontaenously (spelling??).
            • spencers
              • Jan 2004
              • 1150
              Mine does that too. And I know for sure I have enough coolant. I've checked.
              I hate it when the coolant light comes on. Had a girl in the car last night and asked why the lights were on and I had to say I don't know because nothing is wrong. Also my low beam check light comes on when I turn on my headlamps too. I don't know why because the low beams work just fine (Bosch H4s with Osram Silverstars).
              What's the means of replacing the sensor? Is it just the connector on top?
              • e30Matt
                • 5077
                AFAIK you just unscrew that one, and replace it with a new part. What year/model is your car, I'll look up the number.
                • spencers
                  • Jan 2004
                  • 1150
                  87 e
                  • e30Matt
                    • 5077
                    Part number for that switch is 61 31 1 378 320. :up:
                    • spencers
                      • Jan 2004
                      • 1150
                      Where would you suggest getting it?
                      Bavauto has it for $25 :shock:
                      • e30Matt
                        • 5077
                        I'd probably suggest BMA, seeing as we get a discount there.
                        • spencers
                          • Jan 2004
                          • 1150
                          Can't even figure out how to find that thing on there.
                          • e30Matt
                            • 5077
                            Call them on Monday.
                            • spencers
                              • Jan 2004
                              • 1150
                              :up:
