Air Fuel Gauge?
  • BimmerScreamer
    • Dec 2008
    • 413
    Air Fuel Gauge?
    Does anyone have an air fuel ratio gauge they recommend? I want to pick one up before I start really tuning my car.
    Anything can be done
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    Find Geogegraves on here, he can help you.
    Search a little next time.
    Andy
    -Andy
    • george graves
      • 19997
      Originally posted by Matt-B
      • BimmerScreamer
        • Dec 2008
        • 413
        Andy
        I did search and I did find geoge graves, what he offers if nice and a really clean idea but I want something with a little more detail.
        • george graves
          • 19997
          For a narrowband or wideband?
          Trust me, for a narrow band, my gauge is all the info you will get out of a narrowband gauge.
          For a wideband (if you are running MegaSquirt/turbo that is what you want) I suggest Innovate LC-1 or JAW (Just Another Wideband) - but be ready to shell out some money for a sensor, controller and gauge.
          • BimmerScreamer
            • Dec 2008
            • 413
            I am looking for a wideband, but what is the real difference between narrow and wide? the sampling rate?
            • george graves
              • 19997
              A narrow band sensor, in a way, only produces two different readings. Rich or lean. That works fine for an OEM set up. The microprocessor in your ECU adds a bit more fuel if the sensor tells it it's lean, and if the sensor is reading rich it adds a bit less fuel - Do that several thousand times a second, and your mixture will be spot on.
              But for a human eye to try and read a gauge like this is much harder to do. SO a wideband display will tell you HOW RICH or HOW LEAN you actually are.
              Sampling rate has almost nothing to do with it. Any gauge you buy, either mine or someone else's, will sample millions of times a second.
              • BimmerScreamer
                • Dec 2008
                • 413
                thanks for the english explanation, all I could find online was to in depth for me. Your gauge sounds just right for me later on.
                • MC Hammered
                  • Jul 2008
                  • 2076
                  If you are running big boost then a wideband AFR is recommended as running too rich or lean can start blowing things up.
                  Innovate LC-1 is a very good AFR controller but as George stated the setup isn't cheap. The LC-1 is $199 by itself.
                  If you want to read boost and AFR at the same time this is the gauge I use.
                  My 1989 e30 s52 Touring... this is Betty
                  My 1989 325i vert (sold)...this is Nina
                  My 1991 M5 (sold)... this is Veronica
                  Photo comparison: OEM vs aftermarket windscreen for a convertible
                  • liquidgroove
                    • Oct 2007
                    • 66
                    I got a westech AF ratio gauge which has actual AF number to give you better idea of the ratio. Range is limited to 17 to 12 as it's designed for narrowband instead of wideband
                    It won't give you accurate reading as wideband, but at least it provide some idea about current engine AF ratio instead of flashing led light show.
                      • 37832
                      For a gauge, Autometer is a good choice also.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • Danny
                        • 14216
                        ^+1
                        I have an Autometer narrowband and its awesome.
