M20 AFM ON THE M10 IS IT POSSIBLE?
  • ZiMMie
    • Jun 2004
    • 968
    is it possible to use a 90 325i AFM on my m10 motor. and should i expect any gains?
    www.stancefactory.com
  • Jordan
    • 12916
    no, hence no
    https://mtechniqueabs.com/
    • ZiMMie
      • Jun 2004
      • 968
      details y no?/ can u tell me y it isnt possible..explain
      • Jordan
        • 12916
        A m10 uses Bosch L-Jetronic for starters, where as a m20 is Bosch Motronic 1.1-1.3.
        I'm not sure if the plug connectors are the same, but even if it does physically plug in, it won't work properly.
        • ZiMMie
          • Jun 2004
          • 968
          the connectors r the same. ill try it tommorow and let u know. ..i know am hard headed
          • Jordan
            • 12916
            Yeah, have fun with that. :roll:
            • mspiegle
              • 1026
              lol. the car might work better without a sensor plugged in at all.
              Michael Spiegle
              '01 Ford Escape / Daily Driver
              '99 M3 / Track Car
              '87 325is bronzit / wtf car
              '06 Daytona Triumph 675 / Daily Rider
              • James Crivellone
                Head Janitor
                • 6305
                The earlier ETA Versions may function, the later 325i ones will not
                • nzer
                  • 122
                  320 pre facelift uses L-Jet - so does the 323. You could always try with one of them.
                  They will give the wrong readings however and won't work - could always try transfer the electronics if the AFM is larger - even then the TB will be smaller. So it really isn't worth it.
                  I doubt little mods like that will see the M10 crack 45 wheel kW
                  • Digitalwave
                    is a poseur
                    • 6299
                    Do it, it's going to give you like 30hp dude :roll:
                    RISING EDGE
