Car loses power after warming up; 02 sensor didn't help, now what?
  • KevRC4130
    • Nov 2004
    • 332
    My 325i starts right up and drives great for 10-15 minutes. It has full power, can be redlined, idles smoothly (for what it is), and all in all seems perfectly healthy. In fact, it almost seems like "italian tune-up"-style driving helps the engine run how it should. However, after that 15 or so minutes is up, the power is lost, and it ultimately gets to a point where it cannot even rev past about 1000 rpm and simply stalls.
    I replaced the 02 sensor today. That definately made the car idle smoother (it's always had a somewhat oscillating idle, which seems to be fixed). Otherwise, though, the problem is exactly the same.
    Another strange thing is that the car did this for about a week this summer. For some reason, it stopped doing it, and I've made it this long without changing a thing. However, about a week ago, it started doing it again, and it wasn't going away this time. I was expecting an oxygen sensor change to do the trick, but it hasn't.
    Any ideas?
    Thanks!
    Any ideas?
    • 34839
    coolant temp sensor
    • kencopperwheat
      King of Kegstands
      • 14396
      O2 sensor shouldn't have had much of an effect. Def check temp sensor as stated above.
      Originally posted by Gruelius
      • kronus
        • Apr 2008
        • 13032
        Your AFM may be suspect. Check that the flap is not binding, the plug connection is solid, and the resistance is within spec.
        cars beep boop
        • lordofthewaters
          • Oct 2005
          • 714
          Could be a failing fp as well.
          Sarcasm is a body's natural defense against stupid.
          When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
          "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
          Old age and treachery will always overcome youth and skill.
            For that set of symptoms, my first suspicion would be the fuel pump or relay.
              • 34839
              if the fuel pump were bad, it would run poorly when cold too - since cold running can use up to twice as much fuel as warmed up/closed loop. a relay would lead to a no start issue or the car would just shut off.
              check the coolant sensor..
                Not necessarily. The pump or relay may work fine when cold, but misbehave after it heats up. A fuel pressure check when cold and after being driven will quickly tell if the fuel system is the cause of this.
