when off my wipers will not return to bottom of windshield, but wipe fine.
    Wipers on, everything looks fine. But when I shut them off they stop 1/3 from the bottom. Any ideas? Thanks.
    yeah you have to adjust the stop position.
    90 E30 325i
      ok, sounds like something I can do. So, how do I do it? Thanks.
        when they sweep, do they go lower than the stopping position? if not, you have to just undo the wiper arm, and reposition it. if they sweep below the stopping position, then you have to get in there at the linkage under the cowl. you can undo the bolt to the motor, reposition the linkage at the appropriate stop position and bolt it back.
        the system detects the stopping point at the motor, not at the linkage. so you have to 'align' the linkage to the motor.
        90 E30 325i
          Yes, they wipe lower than the current stop position. Can you run that procedure by me one more time? Are the linkage splines keyed so that I will know where the wipers should be?
            I am also having this issue. Although I fear my linkage itself needs to be replaced.
            '88 325ic
              #1 - stop the wipers. let them go to their non ideal rest position
              #2 - disconnect the wiper motor to wiper linkage connection
              #3 - wipers are now loose and can be moved by hand. reposition to desired rest position
              #4 - reconnect wiper motor to linkage connection
              90 E30 325i
                If the wipers move through the normal range, the problem isn't going to be the linkage. I sort of recall that there's sensor like object that can get dirty and interfere with the park function.
                  yes, the position track in the motor should also be cleaned.
                  90 E30 325i
                    Would that be why my wipers are jittery on intermittent?
                      What do you mean by the "position track in the motor"? It is finally warm enough to attempt to fix this problem. Thanks.
                        this will help
                        90 E30 325i
                          Thank you!!!!!
                            All fixed. Thank you for your help. It worked just like you said.
                              no prob
                              90 E30 325i
